Hello everyone, I am a cinema technician from Indonesia, I work in an independent cinema, so I have minimal fellow technicians.
I am currently operating a Barco DP2K-10S . Recently, I noticed a permanent blue blotch appearing at the bottom right corner of the projected image.
The blotch is always blue, regardless of the color being projected.
It is most visible on a full white test pattern, but it can also be seen (less strongly) on all colors.
The position is fixed and does not move.
The appearance is more like a blurred spot/cloud, not sharp pixels or lines.
What I have already tried:
Cleaned the porthole glass.
Removed and reseated the lens.
Swapped lamp house with another unit.
In all cases, the blotch remains the same.
My questions:
1. Do you think this is prism contamination rather than a failing blue DMD?
2. Has anyone here successfully cleaned or refurbished the prism block or dmd chip in a DP2K-10S light engine?
3. Would replacing the blue DMD chip solve this, or is it more likely that the entire optical engine needs servicing/replacement?
20250920_232452.jpghttps://drive.google.com/file/d/1FA1ka9Zn6daO6hj9jH8tyvpH-VYRveBY/view?usp=drivesdk
I attach sample pictures of the screen output for reference (white test field, with the blue blotch visible).
Thank you in advance for your advice and experience.
Best regards,
My questions:
Best regards,
