Thank you!
I worked with them for several years over at Dolby. DolbyKinoton_2.jpg Dolby also had a Kinoton 16/35mm magnetic/optical combo projector too. But I never saw it used. DolbyKinoton_4.jpg
When I first started working with those projectors, I had trouble remembering
the threading path, so one night I made this threading diagram. Eventually, I
got so good, I could run those projectors with my eyes closed.
(although that did make focusing and change-overs a bit difficult) DolbyThreading.jpg
Reason: I Don't Remember
I have one customer in the LA metro that has a pair of DP-75s in regular service.
Originally posted by Jim Cassedy
When I first started working with those projectors, I had trouble remembering the threading path​
Was that on the FP-38E? I used one at the Egyptian, but apart from one occasion, only for 16mm. There was also a pair of Norelco AAIIs (DP70s) for 35 and 70. There was one single show in which I used it for 35, which was a silent short from 1909 shown at a festival, that needed to run at the slowest frame rate possible. While the Norelcos could go down to 16, the flicker was seriously bad below around 20. The FP38-E, however, was almost flicker free even at much lower frame rates, so I converted it to 35 for that one occasion. I also found the 35mm threading path confusing, and ended up photocopying a blowup of the framing diagram in the manual, laminating it, and sticking it on the wall in front of the projector. But 16 I could pretty much do in my sleep. I suspect that it was simply a case of practice makes perfect.
I appreciate the offers of assistance. I have some parts that I was looking to give to an institution that still uses them. Not many of these out there anymore.
@Pete- These are larger pieces and shipping might be too costly depending on worth.
Yes, I think that was the model number. I have a picture of it somewhere.
It did 16 & 35mm and I think it was also possible to run sep mag tracks
in 16mm on it too. ( Dolby still had some 16 & 35mm mag film
decks and dubbers for a while when I first started working there)
